69 Fuel cap
  • Thread starter Thread starter Steve69
  • Start date Start date Apr 27, 2006
Steve69
233
  • Apr 27, 2006
Hey Guys I found a fuel cap that will fit under the pop open cap. You
have to remove the old spring and seal from the pop open. The cap is
Napa 703-2005 part #.
Steve
1969mach1351
285
Sacramento, CA
Apr 27, 2006
  • Apr 27, 2006
Good to know. I did a search on Napa's page but it came up with nothing for that part number (their webpage isn't very good). Just last week I had the garage open and after about 10 min of the back half of my car being in the sun fuel started dripping out of my tank. After getting fuel and going up the driveway and into the garage any air in the tank moved forward so any expansion that occurred can only force fuel out.
Steve69
233
  • Apr 27, 2006
I had my mustang painted last year and I didn't want any fuel comming
out on the new paint job. I think I tried about 6 caps before I found one
that fit it really nice. To tell you truth Im not sure what car the part #
fits but it works.
Steve69
1969mach1351
285
Sacramento, CA
May 23, 2006
  • May 23, 2006
I got the cap but you did you remove the spring piece?
Steve69
233
  • May 23, 2006
Yea
I took the pop off center off. That the peice with the spring. I ground
the center out and there is a small screw underneath the spring cap and it holds the spring in place. After I ground it down it looks like that center cap
might come off with a screwdriver or a pliars. At the time when I ground
it seemed like the only way it would come off. I also left the screw in
and adjusted back against the new cap to take up the play in the pop up
lid.
Hope this helps.
Steve
1969mach1351
285
Sacramento, CA
May 24, 2006
  • May 24, 2006
Thanks, works great now. Does this cap vent any of the pressure that will build up?
Steve69
233
  • May 24, 2006
To tell you truth Im not sure. If you look at the filler neck right were the
rubber meets it on the cap there is a dimple there. I beleive that is there for a vent
because its not a total seal. I drove my car about 25 miles with it and
didn't have any engine problems and everything seemed good.
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
P
Resolved P0457 with intermittent fuel odor in cabin
  • PSKSAM2
  • Jun 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2025
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
