69 Mach 1 hood scoop placement
Are you talking about the nonfunctional cobrajet scoop with the blinkers in the back? On the underside of the hood you'll see the small clearance contours in the hood reinforcement for the turn lights near the rear of the hood. I think there are holes in the reinforcement for the attaching studs. I don't know what the actual measurements are but you should be able to get pretty accurate placement from the corresponding points on the bottom side of the hood.
Thanks so much for the info. It is just a mach 1 scoop w/out the blinkers. But I think I got a good idea of the placement from the pictures in the previous blog. Thanks for your help!
