Ford recommends 5 quarts in a 5.0, and 6.0 quarts in a 4.6 and 5.4... V10... I have never, ever EVER seen one be off as long as the dip stick is not bend or modified any way. Another mistake you might be making is not letting all the oil out of the pan before you put the drain plug back in, this when adding 5 quarts, you can be well over the full mark. Every time I had 5 quarts to my 5.0, it reads in the middle, where it should be. Every time I've ever done an oil change on any Ford car with an unmodified dip stick, it has ALWAYS read correctly. Now you guys can take hear say from the internet, or can take the advise from someone that does it every day. Which do you choose?
