i've been considering something like this for a car for my daughter when she's old enough to drive, but haven't researched it much yet. the engine bay in the 71-73 stangs was made to accept the boss 429 and the sohc motor is about the same width as the boss '9, maybe a little narrower. i'm thinking it should fit but you'll have to do some modifications to both the car and the engine more than likely. i know you'll need custom mounts and probably a modified oil pan and you may also need to modify the crossmember on the car a little. then again it may drop right in with custom mounts but i wouldn't count on it. my only other concern would be the exhaust manifolds on the engine and whether or not they will clear the shock towers.
