  • 1994 - 1995 Specific Tech
  • Thread starter Thread starter Andy gt
  • Start date Start date Mar 24, 2008
A
Andy gt
  • Mar 24, 2008
How do i pull alot of power out of my car without alot of work???? i have a 95 5.0 mustang gt
earleys94gt
1,223
Ashley, Ohio
Mar 24, 2008
  • Mar 24, 2008
That's the million dollar question...
Well, gears are a popular mod. They don't give you any extra power, but they give you a 'kick in the pants' feel. If you have a manual do some 355's or 373's, and if you have an auto go no lower(numerically) than 373's.
To pull some serious power, you will have to build the engine; or just put on a supercharger lol.
While they won't set the world on fire, little things like new plugs and wires, cap and rotor, and a timing increase can get you some more power.
Then there are the bolt-on's like a cold-air, pulley's, high flow or off-road cataltic pipe, etc. Do a search and you should find more information.
Good luck.
Pokageek
2,767
MA, USA
Mar 25, 2008
  • Mar 25, 2008
For every FULL revolution in your gearset, you take a 1/2 second off your quarter mile. 2.73 to 3.73 will yield you a little better than .5..so if you are running 15.1 QM time then you will be running 14.6. Now THAT is roughly equivalent to adding 50 HP or bumping your car to 270HP. 4.10's will yield you even more go.
T o be honest..Todays cars yield a two fold problem for our outdated motors..First of all they are doing more with greater technology and less cubic inches and ALSO building BIG a$$ engines. The stock 5.0 is waaaaay outdated in technology. It's putting out 220hp with crappy heads, intake, and choked by emissions (compared to todays cars).
Just to get it on par with v6's today and some v8's you'd better at LEAST h/c/i. If you want to beat the competition, you have to supercharge in ON TOP of that. Then you will be blowing them off the road though, lol. It;s fun when someone thinks they will win and u beat them tho. That's why I wouldn't enjoy a vette or a viper..no surprise, no fun.
But the competition is FIERCE. Look at all the chevy's with 6.x liters coming out churning 360+ to 400 + HP, infinite v6's with 300+ HP, Dodge with 340-400+ HP V8's. And they are all street friendly.
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 25, 2008
  • Mar 25, 2008
Here's some easy mods that'll gain you some performance for next to nothing:
1. Increase timing advance to 14* at idle.
2. Remove fenderwell air silencer from airbox.
3. Remove mesh screen from MAF sensor housing and grind away the bar in the middle with a dremel.
4. Remove some unnecessary weight: strut tower brace (6lb), smog pump (7lb, use shorter belt), rear diff. dogbone weight (8lb).
5. ASP underdrive crank pulley. Not quite free ($39) but if you remove the smog pump, you're gonna need a new belt anyway so do both at the same time.
6. Hollow out the cats.
Then when you've saved some money you can get started with bolt-on parts. I recommend a 3.73 ring & pinion as the first bolt-on (best bang per buck).
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
F
Drivetrain TKX Shifter Position Question
  • fasterthangas
  • May 29, 2026
  • 2 3
1994 - 1995 Specific Tech Jul 4, 2026
WhiteCobra95
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
