  • SN95 4.6L Mustang Tech
75 Shot?
  • Thread starter Thread starter Modularstang04
  • Start date Start date Jun 3, 2005
M
Modularstang04
  • Jun 3, 2005
I'm thinking about running some nitrous on my 04gt. Would a 75 shot with a wet system be safe?
Red35th
609
Houston, TX
Jun 3, 2005
  • Jun 3, 2005
Yes, very. Just get an rpm window switch (msd has a very good digital one), one step colder copper plugs and check the a/f on a dyno. A wet kit is great because you can adjust the a/f ratio using fuel pills, not by messing with fuel trims or the MAF curve like a dry kit.
Type in "NX wet kit" into the search feature...read every thread you can. Knowledge is your friend.
01SN8K
135
  • Jun 4, 2005
yes it should be safe. as stated research as much as possible. do not ever use any platinum plugs. they will foul up. buy as many features as possible. a wot switch, window switch and purge would be some things to invest in. most kits already include the wot switch. the window would be an added safety feature as it only allows the nitrous to spray in a set rpm range. the purge will clear the lines and allow you to recieve 100 nitrous every time.
MyEarsHurt
918
  • Jun 4, 2005
A wet kit is a good investment if you are only spraying a 75 shot. Like everyone else said, a window switch is a good idea. Another good idea would be a fuel pressure safety switch, so if your fuel pressure drops too low while running the nitrous, it will kill the nitrous. If you wanted to be a real freak about safety, then you could get a wideband commander. It will cut the nitrous if your A/F goes too lean which is an awesome feautre...too bad a wideband commander is $450.00.
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
