8.8 differential cover- paper gasket or RTV or BOTH? please input
I was just wondering how most people seal up the differential. I bought a Felpro paper gasket at autozone. Then, I happened to think that I may need some silicone gasket maker, so I asked the guy at autozone and he recommmended the heat resistant RTV silicone (red). But I have little faith in what he told me due to the dumbfounded look on his face. So, now I'm asking the real Pro's. Please help me out. I'm planning on installing cover this evening. If you reply with what method you used please also add if your satisfied or not. Thanks everyone.
I always have used black RTV alone. I know that when I pulled the diff cover on my 03 Mach 1 there was no gasket just black RTV and I bought it new so that is the way it came from Ford.
Don`t worry about the color as long as it is rated for enough heat. I used red, because that is all that is needed for the heat in the rear end. But black is fine, or anything else with adequate heat resistance.
Scrape off all the old gasket, and use some brake cleaner to prep the surface (brake cleaner evaporates leaving no residue).
I put on a ¼ bead, put in the bolts at a turn or two past finger tight. Then let the silicon set up for around ½ hour. Then torque the bolts to speck. Remember, there is not much pressure in the rear end compared to the typical engine application. You mainly want a good “lubricant-tight” seal. You don’t want to squeeze out all of your sealing silicone.
I would never use a solid gasket.
