brianj5600
My calculations put an Explorer cut on one side at 57.25". That should work great in a 65. I would not be suprised if you could do it for $500 or less. Disc brakes, posi, 31spl axles, 3.73 or 4.11 gears what is not to like? I have less than that in my 95GT 8.8 swap including a new driveshaft. I may look into an Explorer to allow off the shelf 15" wheels to fit my 67. You would have to do some serious shopping to get those things in a 9" for that price.
The key is getting the right thickness of "C" clip and properly maintaining your differential. Most people don't realize there are different thicknesses, and end up with lateral axle play. Which causes heat and wear problems.
There's another reason for eliminating the C clips and axles. This is also to rid it of the inferior bearing/race and replace it with a stronger bearing and harder, thicker race. Just me, but I don't like the fact that with C clip axles, the inside race for the bearing IS the axle.
