8-bolt flywheel with a 07 GT clutch?
lightblade
366
I'm puting a forged cobra crank(01) in my 07 GT. The new crank is 8-bolt so it wont work with the stock 6-bolt gt flywheel. My question is will a 01,03,04 stock cobra 8-bolt flywheel work with a 10.5 inch stock 07 GT clutch? I'm thinkin it will, but want to be 100% sure before i buy a new flywheel. Thanks.
I was told that my car came stock with a forged crank. Is that not true or is there some other benefit to swapping to the Cobra crank? I am also pretty sure that the stock clutch is 11" so you have to change the clutch and flywheel together to go to a 10.5" setup.
Nope, cast iron crank 6-bolt. I thought it was 11'' but all the after market twin disc clutches are 10.5 witch i will get and aluminum 8-bolt flywheel to go with eventually, but for now I want to run the stock clutch and 8-bolt cobra flywheel.
