8" gearswap problem...
  • Thread starter Thread starter 65notch
  • Start date Start date Aug 22, 2005
65notch
303
661 Cali
Aug 22, 2005
  • Aug 22, 2005
i was swaping out the 2.80s to 3.55s in my 8 inch today and i ran into two problems. the pinion doesnt sit deep enough(seems to need a spacer between pinion and rear bearing) AND/OR the ring gear, for proper backlash, is set way off center from where it should be. so i think i need either a spacer for pinion and ring or one or the other.
has anybody else ran into this problem? im using richmond gears
10secgoal
2,801
San Diego
Aug 23, 2005
  • Aug 23, 2005
How far off is it ? I don't know the technical term, but there are supposed to be spacers. The 5 or 6 bolts that hold in the pinion to the carrier should have spacer(s) between it, and the carrier.
65notch
303
661 Cali
Aug 23, 2005
  • Aug 23, 2005
those adjust pinion depth. i messed aroudn with those for a long time but they dont do it enough. the pinion needs to go into the ringgear more. it probably needs to go in about 1/8 to 1/4 inch further. thats why im thinking there is sopposed to be a spacer behind the pinion itsleft
thehueypilot
1,084
Medina,Tennessee
Aug 23, 2005
  • Aug 23, 2005
You need a crush sleeve that adjusts/eliminates the gap while putting a slight preload on the bearings. It should come with the install kit for new gears.
iskwezm
4,159
20
79
Rowland Heights,California
Aug 23, 2005
  • Aug 23, 2005
the crush sleeve gets crushed at about 250 ft. lbs.
1320stang
4,329
23
89
Edmond, Oklahoma
Aug 23, 2005
  • Aug 23, 2005
Sounds like you should adjust your spanners to move the ring gear over.
Got any pics?
65notch
303
661 Cali
Aug 24, 2005
  • Aug 24, 2005
ok, the crush sleeve came with the kit, and its installed and properly tourqed with proper turning torque.
1320stang: for the ring gear spanner nuts- the ring gear was already adjusted to the proper backlash, so if i moved it any more it would kill the backlash. but you have the right idea.
here is what we did...
made some calls and found out that because of the swap from a 2 to a 3 ratio, i needed a carrier that has the proper flange for the size difference. so i bought a new carrier today, installed it and got the right backlash, depth, preload and gear pattern.
now she is in the car, i drove her a little tonight to start the heat sink process.
so anyways, now we know that carriers need to be changed which doing a swap from 2 to 3.
thanks for the suggestions guys
10secgoal
2,801
San Diego
Aug 24, 2005
  • Aug 24, 2005
hmm, I didn't need to do that. Think it's the particular year you got ?
65notch
303
661 Cali
Aug 24, 2005
  • Aug 24, 2005
i think so. i talked to a guy at richmond first, the said something about the carrier but not a whole lot. so i called up a local diff. place and they said the problem is the carrier. from what i was told, the earlier 8" need to have the carrier changed whem jumping gear ration like i did. but the later 8" diffs have a carrier that will work on both or something. because the carrier i had to buy is out of a later model 8".
1320stang
4,329
23
89
Edmond, Oklahoma
Aug 24, 2005
#10
  • Aug 24, 2005
  • #10
Hmmm, it seemded to me that if the pinion wasn't deep enough by an 1/8" to a 1/4" and your ring gear wasn't centered properly, how would you know if you had the correct backlash? That being said, I've never set up gears myself, one of my buddy's owns a drag chassis shop and he does them for me and I've only watched, so all I know is from observation and questioning. I do know that when your checking for pattern, you should put some sort of load on the ring gear, the palm of your hand works okay, to take out some of the slop to see the pattern right. You can use a axle and hold onto the shaft to offer resistance as well, but the palm deal works fine.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Aug 24, 2005
#11
  • Aug 24, 2005
  • #11
I have a few 8 inch rears and I checked them and found that some have a smaller pinion bearing flange and mixing them would make the pinion depth be to short for adjustments. I still have the 8 inch in my early stang with 3.55 gears and a Lock-right posi unit and I had no problems with pinion depth but 65notch is right about the change. maybe the thicker flange was for the V8 and the thinner for the 6 cylinder
65notch
303
661 Cali
Aug 24, 2005
#12
  • Aug 24, 2005
  • #12
we thought the pinion wasnt deep enough because of how it was hitting on the ring gear tooth. i know i have the correct backlash because i use a dial indicator and adjust the spanner nuts to acheive proper specs. you are right about putting a load on the ring gear. we use our hand or what seems to work better is stuffing a rag between the ringgear and the housing. it drags it a little better with less effort.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • dan50
  • Jul 18, 2026
dan50
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
