8 plug head on 88 2.3
  • Thread starter Thread starter 88Stang2.3lx
  • Start date Start date Jul 18, 2006
88Stang2.3lx
  • Jul 18, 2006
i was looking into getting a 8 plug head for my 2.3 4 cyl. What other then the heads, and more plugs will i need/what modifications/what do i have to do to make it work on 8 plugs?
stykthyn
5,232
2,652
223
gainesville
Jul 18, 2006
  • Jul 18, 2006
why would you want to?
anyway you would need the computer/harness, and
the coil packs
just do a 2.3t swap I am sure it would be easier
88Stang2.3lx
  • Jul 20, 2006
well my friend whos building up a 2.3 turbo said that a 8 plug head gives more power etc.
im thinking of buying a 5.0 (OH NO) and maybe supercharging it, so i dont know if i am going to be seriously modding my 2.3, becase the power gains are kinda limited, but im not sure yet, i may just turbo the 2.3 and redo everything and get it bored like .30 over, but im not sure yet
R
RustBucket
585
Buford, GA
Jul 20, 2006
  • Jul 20, 2006
Smack your friend. Yes the dual plug motors were rated higher in hp, but there's more to it than the head. There's really too much work involved to put a dual plug head on a block that wasn't set up for one. The older blocks aren't drilled for the crank sensor, the wiring harness needs to be modified as the sensor plugs are different, you'll need an oil pump drive to take the place of the distributor you've got now. You'll need the MAF and associated parts, The DP computer.... basically sell your car and buy a '91 or newer.
The only dual plug heads proven to anything are the 95 and later 2.5 heads, and they're only a little better at low lift.
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
C
Fox 1993 LX 2.3 Wiring
  • Coyoteswap93
  • Jul 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2026
AeroCoupe
Door wiring, Unknown plug
  • TripleYellow
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
gkomo
W
a/c compressors i d
  • waxman
  • Jan 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
