W waxman 20+ Year Stangneter Aug 6, 2004 49 7 18 central il Jan 24, 2026 #1 Jan 24, 2026 #1 i have an 88 lx,2.3,with ac. i m looking for the clutch,pulley parts,but not sure what compressor i have. its small,round,not long like others i ve seen. can someone help me out? thanks factory a/c
AeroCoupe lube between the nut and the face. I know my lubes Founding Member Oct 28, 2001 6,202 4,300 183 Claremore, OK Jan 24, 2026 #2 Jan 24, 2026 #2 Can you post a picture?
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,535 21,704 234 Box behind Walmart Jan 24, 2026 #3 Jan 24, 2026 #3 Do you have the 6-rib pulley? If so, it [should] be (if factory installed) an SD709 compressor. If so, this should be the clutch assy that you need: https://www.carparts.com/details/a-c-compressor-clutch/4-seasons/fs47997
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,360 18,106 224 Massachusetts Jan 25, 2026 #4 Jan 25, 2026 #4 Factory compressor would be a nippon-denso 6P148A Dealer installed air would be the Sanden SD709 Pictures would help
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,535 21,704 234 Box behind Walmart Jan 25, 2026 #5 Jan 25, 2026 #5 Mustang5L5 said: Factory compressor would be a nippon-denso 6P148A Dealer installed air would be the Sanden SD709 Pictures would help Click to expand... That's odd because when I looked, it was the reverse of that. Can't count on nuttin! Did you happen to find a replacement clutch when you looked?
