84 mustang wont start
ryan 80917
I need help... I have a 84 mustang with the 3.8 v6. It has been running rough and stalling out sometimes but only at slower speeds. also sometimes seems like it wasn't getting any fuel at all and sputter and almost die. The problem is last night after work it wouldnt start at all. I didnt hear the fuel pump either when I turned the key on. As i was trying to start it no fuel was even getting to the carb. I am just wandering if it is the fuel pump, a relay, or a fuse. Also, is the fuel pump located in the tank where i would have to drop the tank to change it. Any help would be greatly appreciated. Thanks
re
just had the same thing happen to me the other day...its worth a try to check the relay out which is located under the driver seat...if its good then its the fuel pump and yes its in the tank so you have to drop the tank
