85-86 GT Marchal Fog Lights Retrofit
cruj1
Has anyone retrofit these 85-86 foglites to non GT? I have all harness, switches, lights, bar, fascia, etc, question is about the fog light relay. Is it still available from Ford, or the aftermarket, or is already on the IP like most of the rest of the wiring harness. If so, where is it?
You don't need the stock piece to get your fog lights working. Go down to your local parts store and get a couple of off the shelf 30 amp relays (one for each) or one relay that's at least twice that size. Wire it off of that stock switch you've go there like you'd wire any other relay operated device and you're in! I ditched the stocker long time ago because it was barely big enough to handle the lights. That particular relay used for that purpose is not worth tracking down.
