85 serpentine belt
removed a\c of my 85 stang and got a belt for a\c delete. problem is the belts rub together on the water pump and the belt barely fits on the pulleys as it is so I can't get a shorter belt. I still have smog pump on it and tensioner when tight presses belts together the belt diagram says it should work but it doesn't whats the problem :shrug:
You said you removed the A/C compressor but didn't say anything about moving the power steering pump to where A/C compressor was. Did you do that or no?
