86 5.0 questions
  • Thread starter Thread starter redknight290
  • Start date Start date Nov 5, 2007
R
redknight290
26
  • Nov 5, 2007
hey everyone
In a few months i will finally be getting a 5.0 mustang. My favorite year looks wise is the 86 GT, but i've heard they had a few problems with them. First off i have heard that that the motor has no top end power due to the heads used that year and also that the higher compression pistons limit the cam choices. My questions are. What life cam do you think an 86 motor can take. and if i replaced the heads cam intake exhaust would it benefit as much as an 87-92 motor and have some top end to it.
thanks guys
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 6, 2007
  • Nov 6, 2007
Replacing your top half with an 87-93 top half will help you power wise the E7 head is a much better head than the E6. The 86 motor did not have valve notches in the pistons for bigger cams however I have heard of people running the Motorsport B cam with no ill results. It has more duration and .480 inches of lift. I would recommend that you check piston to valve clearance first and maybe even look for a set of GT40P heads to go along with that B cam.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 6, 2007
  • Nov 6, 2007
Your best bet is to buy an 89-93. They have more HP and they are tuner friendly. They are roughly the same price to buy, but you will be spending your first amount of money just to get it up to par with an 89-93. You might as well put that money towards mods on the newer 5.0L.
R
Rdrcr
77
Thousand Oaks, CA.
Nov 6, 2007
  • Nov 6, 2007
Just like the previous posters have mentioned, the cylinder heads and the flat top pistons are the main issues with regards to aftermarket parts. Of course, SD (speed density) does not help with regard to tuning.
If you are planning on installing better heads and a bumpy cam a later model Fox might be a better choice.
The '86 5.0 GT was designed for low-end power and little else. The above issues are not a major concern for my GT. I plan on installing a supercharger and when the motor gets tired, it gets replaced.
Mike
KAILUAZ
333
St Pete, FL via Kailua, HI
Nov 6, 2007
  • Nov 6, 2007
Don't let the engine alone sway you, we all know 4 eyes are the best Mustangs out there!! 87+ are a dime a dozen.
Vinnietbird
584
  • Nov 6, 2007
I'm using an '86 engine,and have replaced the topend and cam (and Mass Air),and have had no issues with the setup I'm using.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
