86 and 89 to 93 map sensor
noslow1986
274
oswego Il
is there any difference in 86 and 90 map sensors inside. now i know u can cap off the vacuum line but i was thinking maybe there is a difference on the inside between the two. i switch to mass air and runs crappy when i cap off the vacuum line. auto zone says they are the same but i dont trust them
Ford says they are different. Not sure what the difference really is, or if you can swap them with one another....but Ford has different part numbers for the two.
map and bap sensors are the exact same part, the only difference is whether the port is attached to vacuum line or left open to atmosphere from everything i've read.
