Drivetrain 86 Differential Into 94gt
yeah it will fit .. personally Id just swap the 94 axles and brakes over to the 86 diff and housing, if the 86 hasn't been converted to 5 lug disk already. JFYI the housings are identical its just the axles are shorter in the fox housings
I've had 28 splines in my car since 1999. I probably have about 50 passes on it with slicks. Most of them were on motor with about 400hp. Everything is going to break eventually, but if you are not going to run slicks you are definitely going to be fine with 28 splines.
Kurt
