86 foxbody
nocomp
peekskill ny
ok so i bought a foxbody this is my first mustang i ever owned its a 86 5.0 302 i added trickflow head and intake car started up fine after but now im having a issue with start up an it cutting off on first start it will start then warm up an cut off but then i try to crank it again it wont start i checked for spark on 1st crank it has spark but then i cut car off and try to start it again wont start and no spark was wondering should i also upgrade coil and distributor and car also came with msd box
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,326
5,594
193
polk county florida
First put some punctuation in your posts, one long sentence is hard to understand. Then go here:
Do this checklist step by step, take notes and if you have any questions post them in this thread.
I know you don't have a surging idle but as noted it will help you resolve stalling issues too. Just don't skip around.
Thread starter Similar threads Forum Replies Date
W New guy, 1989 foxbody The Welcome Wagon 1
S 1993 Mustang 2.3 L Automatic A4LD Transmission - Help 2.3L (N/A & Turbo) Tech 2
M Engine 87 Foxbody Hesitation at High RPMs Fox 5.0 Mustang Tech 15
D 1989 Dash Harness Problems Fox 5.0 Mustang Tech 2
F Advice needed for Foxbody build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
9 92 foxbody front disc brakess Fox 5.0 Mustang Tech 1
T 93 convertible torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
S 391 swap into foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
F Brakes Hydro boost foxbody Fox 5.0 Mustang Tech 8
8 Electric fan problem Fox 5.0 Mustang Tech 2
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 3
A Car starts but dies Fox 5.0 Mustang Tech 2
8 Coolant leak Fox 5.0 Mustang Tech 4
spiegs throttle cable removal and install Fox 5.0 Mustang Tech 8
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
1hot87gt Love my FoxBody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
K New Member introduction 1990 Foxbody Hatchback The Welcome Wagon 1
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
E Best tires for 88 Foxbody GT? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
K Is my foxbody cammed? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
White85fox New from Idaho The Welcome Wagon 3
Foxslider SOLD WTB: 87-93 stock foxbody axle out of 8.8. Drivetrain Parts 0
M 93 foxbody 347 stroker megasquirt 2 pnp initial timing set up?? advice Digital Self-tuning Forum 6
S Fuel Explorer Throttle Body.....What Years Will Work On Foxbody Fox 5.0 Mustang Tech 5
12Pack WTB/Trade Wtb foxbody, FL Fox Body Mustangs For Sale (1979-93) 0
S Motor Mounts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S Old Foxbody owner looking to own again. The Welcome Wagon 4
K What's it Worth? 87 Fox GT What is it Worth?!?!? 11
T Exhaust Replacing cats with O/R x pipe and need a tuner Fox 5.0 Mustang Tech 6
mustangmccance Foxbody owner from Iowa The Welcome Wagon 14
T Aod transmission issues Fox 5.0 Mustang Tech 1
T Aod shifter linkage 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
Foxslider Foxbody junkyard direct replacement axles 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
T Drivetrain Is it worth it to rebuild an aod transmission or get something else? Fox 5.0 Mustang Tech 18
T Engine Foxbody idling surging and stalling Fox 5.0 Mustang Tech 10
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 11
P Fox Has anyone ever used sn95 emission valve solenoids in a foxbody. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Rancho GT-III, Foxbody Mustang Swaybar Parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
5 NEED ADVICE FROM COMMUNITY MEMBERS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
T Heater Core fix 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
B Drivetrain Foxbody Rear End Maxed Out Fox 5.0 Mustang Tech 38
5 3.55 gears for a 87 mustang automatic transmission 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
I 1988 Mustang possible transmission shuddle? Fox 5.0 Mustang Tech 4
8 Engine Turbo fox build hot start issue Fox 5.0 Mustang Tech 7
beyondEOD SOLD MOATES QUARTERHORSE QH EEC Tuner Engine and Power Adder 1
1989LXFOX Engine 2G Alternator Install Wiring Help Fox 5.0 Mustang Tech 3
8 Plz Help! ‘88 Mustang will not idle and runs poorly Fox 5.0 Mustang Tech 4
Serb Progress Thread First Foxbody 408 Stroker 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
