86 gt sitting
  • Thread starter Thread starter p.winfield
  • Start date Start date Sep 8, 2007
P
p.winfield
  • Sep 8, 2007
what should I do before I start a 86 gt that was sitting since 91 in a garage
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Sep 8, 2007
  • Sep 8, 2007
change oil, Prime oil pump, drain and replace the gas (if you can call 16 year old gas - gas anymore) I would maby try and move the crank back and forth a little with a jhonston bar to maby help keeping it from spinning a bearing. make sure the plugs are not all rusted by now. And maby squirt a little lube down each cyl when the plugs are out.
93 LX
3,081
Norwalk, CA.
Sep 8, 2007
  • Sep 8, 2007
when you change the oil use a thin oil to replace until you get it running. When doing my 82 Capri several years ago I spun the motor without plugs until it built oil pressure. Then I replace the pugs and fired her up. It smoked and ran like **** but after it warmed up things fell back in to place.
Allen
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 8, 2007
  • Sep 8, 2007
Give it to me!
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,081
224
Massachusetts
Sep 9, 2007
  • Sep 9, 2007
squirt a little oil in the spark plugs holes and turn the motor over by hand a few times.
First time you crank it with the starter, unplug the coil wire and turn it over so it won't fire. Do that for maybe 10-15 second bursts (let the start cool between then) and then try to live crank it over
z2o_what
309
princeton, WV
Sep 9, 2007
  • Sep 9, 2007
why has the car been siting for 16 years?
P
p.winfield
  • Sep 9, 2007
It has been sitting for 16 year , because my friend got a new truck at that time. It has only 5823. miles .
D
Daggar
3,902
  • Sep 9, 2007
PICS!!!! I wanna see pics of the inside, outside, and under the hood!
Do you own the car now?
P
p.winfield
  • Sep 9, 2007
I will post pic at a later date . It is dusty on the outside ,and the inside is a-1 . It was never in the snow and only once in the rain . I will be moving it to my house in a few days .But must first find out what to do before I start it up.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
For Sale 1984-1986 GT GAUGE CLUSTER TRIM PANEL
  • jiminecricket
  • Apr 27, 2026
  • Interior Exterior Parts
Interior Exterior Parts Apr 27, 2026
jiminecricket
J
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
