I was just wondering if the heads for a 1986 mustang 5.0 were the same as the 85 gt 5.0. The reason for the question is because I end up seeing alot of aftermarket headers for the 86-93 years but nothing for 85 and before. I would think if the heads for each car were the same then you would be able to use 86 headers on an 85. Also if I do end up using an 86 header setup would I be able to go with 86+ h-pipe and aft-cat setup considering (from what ive seen and heard) that the exhaust setup for the 85 and lower is from a split single exhaust and cat
. It looks really tight and awkward to get the setup im looking for in there. I have never seen the underside of an 86+ but i would assume it would be pretty similar. If this is the case it would certainly free up alot of airflow restrictions and probably boost up hp (an sound) very nicely
. Any suggestions of how to make this work would be greatly appreciated. Thanks
1985 Mustang GT 5.0
Completely Stock!!
. Any suggestions of how to make this work would be greatly appreciated. Thanks1985 Mustang GT 5.0
Completely Stock!!
