86 mustang gt convert to mass air
izzy650
:bang: hello guys new to forum i have a 86 gt and had a small eletric fire which melted some wires on the main harness and i would like convert to mass air could anyone help me with this conversion what wiring,computer,ect do i need any help would greatl thanks :hail2:
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
the harness that melted is behind the engine along the fire wall basicly right were the MAP is mounted at least i think it's the map sensor little black box mounted on the fire wall behind entake
Call the company to be sure, but I'll go out on a limb and say that the harness they have there is MAF compliant (considering there's allot more of those in world than there are SD cars).
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
hey thanks alot for the help some good info I stayed up late last night cut and pliced out probley 1/3 of the harness. after drinking several beers hit the key and had turning over but found a few more wire bad hit again and it started runs very rough think i need to take abetter look .
