Include me in on this.. I found something on the crane website a while back, but it says it is discontinued.
http://www.cranecams.com/pdf/90002015.pdf
as far as my fuel pump, i was planning on getting the entire summit kit (pump/filter/braided line etc) and wiring it to a 12 volt source, and runing it off a rocker switch like NitroNixon stated above.
the main issue i dont get is how the lines will actually hook up to the fuel pump (is it a barbed fitting, or how does the stainess line attach to the pump?)
also, are you guys using your stock sending units to supply the fuel, or going with like a granatelli aftermarket one? what im planning on doing is taking the stock pump out, and the tube that has the sock on it, cutting it off, attaching some rubber hose so it lays across the bottom of the tank, then runing a line from the top of the stock pump, to the electric fuel pump to the filter then to te carb.
anyone have any insight on this? i used to talk to crazy pete alot about this as that is what he did, but i havent seen him in forever
