- Jun 23, 2007
- 2
- 0
- 0
When trying to start, can here fuel pump run, engine will usually try to "catch" once, then just keeps cranking. Some issues leading up to this are: Fuel gage does not work all of the time. Sometimes it shows fuel level correctly, sometime shows fuel level incorrectly, sometimes shows totally empty. Next is that it started to become hard to start, would not stay running once it started unless I gas it more gas. Smelled like it was flooding. Next would be hard to start, once started it would idle, then when pressing on accelerator would kind of sputter til it got to needed RPM. If let off of accelerator, would idle, but a little rough. I suspect a fuel pump, but think it could also be a sensor for reason it will not start now. I think that fuel gage issue could be seperate issue, or part of problem. What do ya think? Thanks for any help.
Wassup Y'all!!! I have been having the same problems with my 90' Lx vert! It would start and run for 15-30 minutes and then die. If I don't turn the key to the off position the fuel pump will run and can be heard running until I switch the key off. I check for spark and it does. I once thought it was TFI but I have a bag o'them and know thru trial/error and testing at autozone it ain't that either. I can tell when it will run by listening to the pump running...If it cycles on and off it will run. If it just runs continuously when I turn key to first position then I know it won't run. Idling or driving seems to make no difference. I've added four new injectors, ECU, TFI, fuel pump, fuel relay, timing belt, TPS checked out fine, and Inertia switch checks out. Fuel pressure is 55psi at the Schrader Valve Do yall think it would possibly be the distributor(stator) or the fusible links(which I cannot seem to find)??? Do you know how this story ended??? Conclusion???
