88 GT, ignition issue? Need help!
88blowngt
68
Dover, Delaware
At least I believe its an ignition issue. Recently I went about putting new valve seals in my E7s. After putting everything back together, I had installed the distributor incorrectly and the car ran like absolute crap, or shall I say barely ran at all as all I got was backfires when trying to crank it. After installing it correctly, setting timing, fuel pressure and TPS voltage just to make sure it seems to run ok, runs alot LOUDER for some reason. Idle RPM seems fine but not perfect at 1100 rpms. Timing at 12 degrees and FP at 39 pounds.
The real issue is, when I try to start the car, I hear a mechanical pinging as the motor turns over and eventually starts. Not the normal noise a starter would make. I took it up and down the street, ran through 1st through third WOT, experienced no issues whatsoever. Other than that, the car runs EXTREMELY rich, black smoke coming out at idle and rev. I know I have no cats, but it wasn't anywhere near this before I tore it down for the valve seals. Any advice is appreciated.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
