88 gt problems
1fast5.0
I just picked up a 88 GT and have noticed a few problems with it that I want to fix...the headlights flicker off and on after about 15 minutes of having them on ( foglights are not on), would the repair kit from 50resto fix this? Also my windshield wipers will only cycle about 5 times and then they stick, I have to turn the switch off and then on in a few seconds, what would cause this? Last but not least, when the car is running and not in gear the clutch fork vibrates back and forth a pretty descent amount (about 1") is this normal or can I tighten the cable up some? Im a newbie when it comes to mustangs, been more of a chevy guy, but picked the car up for a damn good price and low miles on it, 88700 that is. Thanks for the good info on this board and let me know if anybody has had some of the same problems and what they did to fix em.
Sounds like the contact points in your headlight/foglight switch are shot. Ford used really thin crappy wire throughout the entire electrical harness, as a result, headlight switch failures are very common especially when running the fog lights with the headlights. Over time the headlights will flicker regardless of whether the fog lights are on because damage to the switch has already occured. Resolving the problem is pretty straight foward. You need to beef up the wiring on the fog lights by adding a seperate relay to keep the headlight switch from burning up over and over. Once you beef up the fog light wiring, buy yourself a new headlight switch and you should be good to go. Here a good link on the wiring procedure. Not sure how much the kit from Restore 5.0 costs, but the relay and wire will only cost you about $10.00 at PEP Boys or Autozone.
http://www.corral.net/tech/maintenance/foglights.html
I think your problem is just a relay switch, just buy a haynes auto repair manual if u plan on keeping the car and find the relay switch, it probably works the headlights wiper etc...that would be the first thing i would look at.
DC
