88 notch need help with prob
  • Thread starter Thread starter slowallday
  • Start date Start date Mar 9, 2010
slowallday
  • Mar 9, 2010
i can drive around all day in my 88 notch but as soon as i shut the car off it wont start back up just turns over till it cools down has spark and gets fuel just dont under stand this can any one help please
Cobra1741
152
  • Mar 10, 2010
starter might be bad??? alot of times when there cold they will start and when there hot it wont start up again until its cool.
HISSIN50
34
129
Mar 10, 2010
  • Mar 10, 2010
Check for spark, injector pulsing and fuel pressure. There's a decent chance the TFI module has gone south.
Good luck.
slowallday
  • Mar 10, 2010
chaged the TFI allready
Cobra1741
152
  • Mar 10, 2010
ahh i didnt see that you said it turns over till it cools... and ur sure ur getn fuel???
5.0W/5.0
129
Carson Valley, NV
Mar 10, 2010
  • Mar 10, 2010
It will turn over?
I noticed with mine, if I turn the key allthe way, the starter acts like it seizes and the engine wont start, but if I turn the key just enough to start it, it starts fine. Has nothing to do with spark...Just a thought...
HISSIN50
34
129
Mar 10, 2010
  • Mar 10, 2010
What diagnostics were done that led to the TFI needing to be changed? Was it changed with a known good module?
What did you mean about it getting fuel? It has fuel pressure or injector pulsing?
SVO1
Lord of The somethin' somethin' somethin', hell, I
Oct 25, 1999
4,592
Lord of uh, hmm what was it again?
Mar 10, 2010
  • Mar 10, 2010
Is the battery in the stock location? Also when it cranks and not starting is it cranking at normal speed?
slowallday
  • Mar 10, 2010
well the battery is in the trunk and the inj. do pulse if you dis con one of the inj. the car will fire up
N
nicefighter80
#10
  • Mar 10, 2010
  • #10
has the timing been changed?
slowallday
#11
  • Mar 10, 2010
  • #11
yes the dist. has been out
slowallday
#12
  • Mar 10, 2010
  • #12
i can go drive the car now till it warms up shut it off try to start it no good then unplug one of the inj. and it will start right up anyone
SVO1
Oct 25, 1999
4,592
Mar 10, 2010
#13
  • Mar 10, 2010
  • #13
Is the FPR leaking gas back into the Vac system?
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
  • Mindseye007
  • Aug 16, 2026
Mindseye007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
