88gt idling problems
  • Thread starter Thread starter adeezy9183
  • Start date Start date Dec 26, 2005
A
adeezy9183
  • Dec 26, 2005
hey guys i just got a 88 gt with the following mods:
306 built on a brand new block
8.5:1 JE pistons low compression to handle the boost
Crane cam
AFR 165cc competition series heads with wirelocking groove to protect the head gaskets
GT 40 lower intake
Kenne Belle "blowzilla" supercharger with the air bypass valve currently 10 psi but good for up to 22 psi I have read
36 lb fuel injectors
70mm BBK throttle body
77mm C&L mass air
High torque starter
Griffin radiator with dual electric fans
Crane HI6 ignition system
Holley in tank fuel pump
Mac 1 3/4 longtube headers
Mac 3" pro chamber H pipe
Mac 3" pro dump exhaust
Tremec TKO 2 tranny with Pro 5.0 power tower shifter
Centerforce dual friction clutch
New Ford racing flywheel
Ford racing aluminum driveshaft
3:73 gears
[/B]
the problem i am having is that when it first fires up it goes up and down in the rpm's. i mean from like 500 up to 1500 or so and does that till it warms up and then it runs fine. i am thinking i need a new ignition system. maybe a MSD. this is my first mustang and i am on active duty in NC and the car is home in wv so i can only go home every so often. any help is appreciated guys. thanks
P
PRO50SC
1,012
Olney, Maryland
Dec 26, 2005
  • Dec 26, 2005
Make sure the tps is adjusted correctly and also try cleaning your iac valve.
pistonhead351
flim hunter
May 1, 2005
75
  • Dec 26, 2005
mine did that when i first got it, we just turned the idle adjustment screw in a half turn.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Dec 26, 2005
  • Dec 26, 2005
Refer to the surging idle checklist at the top of the forum.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • dan50
  • Jul 18, 2026
dan50
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
