- May 7, 2017
- 11
- 0
- 1
Hello guys I'm having some issues with my 89 lx hatchback stang
Sometimes the car bogs at low rpm sometimes it backfires through the exhaust not just once but over and over until I rev it up, also feels way down on power from a roll, also I just noticed oil pressure doesn't go up with rpms and is sitting kinda low.
It's been a project but I recently bought a obd1 scanner to help diagnose the problem. Had to fix a couple things but now I get
koeo code 11
koer code 44/94 smog pump has been deleted by previous owner
Cylinder balance test I'm constantly getting code 40
So what I've done
Spark plugs
Plug wires
Compression check all cylinders all are within 10%
Changed the injector
Checked the injector pulse with a noid light
New fuel pressure regulator
Checked timing and put to 10° btdc
Checked the ecm was connected correctly
The coil is a newer msd one. I can see spark on #4 plug wire
I also pulled the valve cover and checked the springs for cracks and if the valves were moving while cranking.
Guys I'm at my wits end. I don't want to go carburetor.
Anybody got any advice on what's going on?
Happy Father's day to all the dads
koeo code 11
So what I've done
Spark plugs
Plug wires
