89 5.0 timing issues
  • Thread starter Thread starter witchblade
  • Start date Start date Mar 29, 2007
witchblade
  • Mar 29, 2007
So on my way home the other day my car dies at a red light and will not start back up... finally get it home and look at it.. I had spark at coil but not at dist.. changed cap, rotor, module... car would then start BUT when you put spout connector back in.. vehicle will not idle.. just jumps around alot then dies... sooo changed dist and computer... still same problem..
i have been looking at this damn car for 7 days now.. with no luck.. please help before i set it on fire...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 29, 2007
  • Mar 29, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
witchblade
  • Mar 30, 2007
we have done that.. i'm sorry i didn't post that in there .. just says rough idle.. that is all.. which we know that...
i'm at a loss.. i have no idea what to do..
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2007
  • Mar 30, 2007
You guys with idle problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix!
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
