M my fox New Member Jul 18, 2012 3 0 2 Jul 17, 2013 #1 Jul 17, 2013 #1 5.0 mustang how much hp will trick flow upper and lower intake and thermastat houseing with a 70mm edelbrock throttle body , 8 24lb injectors, 70mm mass air with k&n filter, fuel rail with regulator,
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Jul 17, 2013 #2 Jul 17, 2013 #2 Not enough to make a difference
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Jul 17, 2013 #3 Jul 17, 2013 #3 In all honesty we need more info about your setup before we can answer. On a stock engine that increase will only add 15hp
f8tlfiveo My wife likes my spool and blow-off valve. Aug 8, 2007 1,585 102 64 Lancaster, PA Jul 17, 2013 #4 Jul 17, 2013 #4 injectors will make no difference, intake,tb and maf will but prob not more than 20 hp at the wheel i would imagine. then again i could be wrong.
M my fox New Member Jul 18, 2012 3 0 2 Jul 17, 2013 #5 Jul 17, 2013 #5 stykthyn said: In all honesty we need more info about your setup before we can answer. On a stock engine that increase will only add 15hp Click to expand... 89 5.0 shorty headers h pipes 3" flowmasters elect fan. just looking to wake it up a bit also 373 build auto trans.
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Jul 17, 2013 #6 Jul 17, 2013 #6 Without matching heads and cam that intake is a waste of time
LarsD Founding Member Jul 2, 2002 2,680 119 123 Texas Jul 17, 2013 #7 Jul 17, 2013 #7 Yeah if you are running stock heads it is a waste of effort.
f8tlfiveo My wife likes my spool and blow-off valve. Aug 8, 2007 1,585 102 64 Lancaster, PA Jul 17, 2013 #8 Jul 17, 2013 #8 Better off doing a cheap explorer intake maybe. Much better flowing intake than the stocker
