89' e303...hard intake backfire
porkichu
only when it's hot outside.cam is installed straight up,dist set at 12 deg advance.running really rich.computer toast?a dude let me borrow an a9p for an automatic but i have the horrible t5.please help,not enough cash to guess anymore:mad:
Mine does the same thing, Smells like gas bad at idle but has the lean backfire through the intake when you rev it.
On an otherwise stock car, what is the solution to getting it more fuel.
The previous owner installed the e-cam in mine without any other supporting mods. The FPR and Filter are new (stock) plugs, wires, cap etc. So if its running lean I have to ask, Why would it run lean and whats the solution? While most of you out there have more experience with EFI than I do, just throwing an adjustable FPR and giving it more fuel seems like an extreme step to take.
My car is an 88 and still has SD computer. No code other tham 94 and 44 for lack of smog pump.
Changing the heads, or the cam can significantly change the amount of air that the engine is breathing, after all that's the point. However, the speed density EEC has no way to recognize that change. So based on the reading from its O2 sensors it can only modify the fuel by 12.5% (more or less fuel) from the speed density base tables. MAF cars will modify based on the amount of air that is being moved and recognizes the change in volumetric efficiency associated with aftermarket installations.
Adding an AFPR will give you the ability to get rid of the lean condition, but it will also cause you to enrichen the fuel curve everywhere. The problem is that most power adding modifications don't add an even amount of air flow across the RPM band. So, adding fuel pressure will fix your lean condition, but may make other places in the powerband overly rich. That's obviously a better place to be, but you can do better still.
There are only 2 practical solutions that I can see if you want to run EFI and make significant modifications. Either install an MAF with an appropriate computer, or get a piggyback chip to tune your SD setup. Having the ability to tune it yourself gives you the most flexibility but requires the most work. Installing an MAF can make future modifications less work intensive while keeping you pretty well in tune, but they also add complexity to the system. I like tuning my SD setup, and I don't like troubleshooting MAF problems when they happen. That said, an MAF car tuned correctly will run just as hard as a SD car tuned right, too. To each their own.
Chris
lean will do that!!??? weird.after swwitching back and forth a9l and a9p,it's clear it's not the computer.fuel pressure seems to die but only when the motor slowly dies.should it stay up at 40 psi with ignition on reguardless?
this is totally incorrect. many members on this site as well as the corral have done this including me.
my car was an aod now it has a 5sp and i'm running the same comp.
Your missing the point that lincoln+Ford was trying to make.
You can run A9P in either setup, and not have to worry about frying the ECM.
If you run a A9L ECM in a car that came equipped from the Factory with a AOD. You can fry the ECM.
It has nothing to do with the ECM itself. It has to do with the harness and its wire routing for the NSS and NDS.
As long as these issues are took care of, you can run either ECM.
lincoln+Ford wasnt speaking from a Performance stand point. Just a compatability issue is all.
As long as you keep voltage from reaching the SIGRTN circuit when using a A9L in an AUTO setup, your golden. :flag:
Not trying to hijack the thread. Just want to make sure im understanding this correctly. I have a car that was a 4 cylinder auto and converted it to a 5.0 5 speed with an automatic O2 harness not sure about the engine harness if it was an auto or 5speed. What do I need to check on the O2 harness? and how do i tell if i messed something up in the computer by frying the NSS or NGS? what does those even mean? It runs ok but it wants to die when its cold and hessitates at times.
Thanks,
Colby
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
