89 Fox E Brake Doesn't Work
  • Thread starter Thread starter Michael West
  • Start date Start date Jan 13, 2014
Michael West
41
Jan 13, 2014
  • Jan 13, 2014
So I have an 89 automatic and my e-brake hasn't work since I bought the car. I don't think the cable is snapped as it still has tension when I pull it up, but it doesn't stop the car at all from rolling when in gear. So what could my problem be?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jan 13, 2014
  • Jan 13, 2014
You didn't mention what brakes you had so i'm going to assume stock drums
Stretched cables,
worn out rear shoes
mechanical issues with drum brake linkage.
Michael West
41
Jan 13, 2014
  • Jan 13, 2014
I'm sorry. I have the 03 cobra irs rear end and sn95 spindles in the front.. All disc
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jan 13, 2014
  • Jan 13, 2014
In that case, if it has the adjustable center cable, you might need to tighten it up a bit. It's a common issue that fox mustangs with SN95 rear brakes have weak parking brakes unless you tighten them to the point of just before the rears drag
Basically put the car on 4 jackstands in nuetral and have someone turn the rear wheels while you tighten the center adjustable cable until they start to drag. Then back it off to the point where 2-3 clicks up is all that's needed to have a good hold that should hold on steep inclines without being in gear.
Of course, this is assuming whoever did the install use an adjustable cable. if they used Sn95 cables, it's possible the cables are stretched.
The e-brake does have a self-tightening mechanism. Usually, with the adjustable center cable, it's welded to defeat it and the adjustment is through the center cable. If it isn't defeated, it usually rachets the cable up too tight stretching it.
Basically...there are a few things to check out
Engine Dreaded 5v reference
  • 89foxstang
  • Jun 24, 2026
89foxstang
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
