89 Fully built turbo built 5spd
monstergremlin1
1989 Mustang 5.0 Clean Title Coast High Performance 347 Street fighter long block with girdle
Forged Scat Crank and Rods - Stable to 800HP
Forged Dimond Pistons
Maching/Balancing/Blueprinting
T5 Upgrade- 9310 Main Shaft,Intermediate Shaft,Gears,
Bearing Syncro Kit,Billet Cluster Plate,Billet Keys. Good to 800 HP S PEC Clutch
AEM Wideband
Canton 7 qt oil pan with windage tray
Edlebrock Performer heads Edlebrock Performer RPM II intake
70mm BBK throttlebody
76mm C&L MAF with tuner tube
Pro Turbo Kits single turbo system with Garrett GT45R
Turbo XS intercooler
255 lph pump
42 lb injectors
Kirban FPR MSD 6AL BTM Diablosport Revolution chip
Cobra brakes
Cobra wheels
Sub frame connectors
Eibach Pro-kit springs AGX adjustable struts/shocks
Steeda bump steer kit
Caster camber plates
Steeda rear lower control arms Maximum Motorsports adjustable clutch quadrant
Hurst shifter
Aluminum drive shaft
3.55 gears
underdrive pulleys
Fluidyne Radiator
SSP fan clutch
180 t-stat
Fuel pressure and boost gauges This thing is a Monster!!!! It has been 1 year in the making and has been fully built by Dragon Performance in Denver CO. They shipped the car up to me with a 24000 mile or 2 year warrenty on the motor and trany. It is tuned on extreemly safe 450rwhp/500rwtq @ 7psi, its a low compression boost motor so it can handle way way more. I have way WAY too much money into it and will be selling it at a loss. I moved up here from Denver for a job and just will not have time for it,and I don't want it sitting in the garage. It has 500 miles on the motor,trans,and turbo (all break in miles). I built it to be a sleeper. It is fully built,professionally built,with no corners cut. I have all the recipts ($20,000). It was built to be a sleeper and the body is stock. I can send more pics and videos upon request. Open to trades Or $10500 OBO. Need to sell quick
6000!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! If the car dose not sell in the next couple days I will ship the car to where im moving and the car will be taken off the market
Would you consider doing an escrow service? I am in Texas and will not be able to come look at it. But at 6000, I would definitely consider it. You ship it to Texas, we split cost 50/50. If the car passes my shops inspection, then they release rest of money to you as long as its clear title and what not. Let me know.
EDIT: I am currently living in Wichita, KS but would need the car shipped to a shop in Houston, Tx
Hello? not sure if you've been getting my messages and my account has been acting weird. So I re-registered and I'm still not getting a response from you via PM. I was prepared to buy the car when you had the price set at 7500!!!
