89 GT problem
  • Thread starter Thread starter ID89GT
  • Start date Start date May 26, 2008
ID89GT
1,659
18
49
Spokane Valley, WA
May 26, 2008
  • May 26, 2008
OK so I just recently got an 89 Mustang GT, and am working on fixing it all up, and have run into a problem. Whenever I accelerate quickly, the car will lose power and will backfire quite a bit and will just not doing anything. If I accelerate gradually it won't do it, but that defeats the purpose of the car and ain't no fun lol. I have been told it is the fuel pump, but don't want to go out and spend 150 bucks or so right now for the one I want and it still has the problem. Any help will be appreciated
MarcMonteverde
66
S@c-ToWn
May 26, 2008
  • May 26, 2008
check timming
HISSIN50
34
129
May 26, 2008
  • May 26, 2008
First thing to do is pull codes. If it's the pump, you should see a lean code stored. Or have an assistant watch fuel pressure while accelerating.
Good luck.
93 LX
3,081
Norwalk, CA.
May 26, 2008
  • May 26, 2008
fuel filter??
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
May 26, 2008
  • May 26, 2008
Most likely a tune-up issue.
Run the codes. Give a quick visual to the cap, rotor, and wires and change them if they look burned.
Replace the fuel filter
ID89GT
1,659
18
49
Spokane Valley, WA
May 26, 2008
  • May 26, 2008
I replaced the fuel filter, and it ran great for about 2 blocks. Then it went crap on me and now its only gettin worst. Now I can't even accelerate at all without it going crap on me. It is starting to have problems just gettin the car to start even now Also when it does start, you can hear the fuel pump really good whirring in the back when inside the car, and with the exhaust system on it, its pretty loud to overcome that
93 LX
3,081
Norwalk, CA.
May 26, 2008
  • May 26, 2008
check fuel pressure
HISSIN50
34
129
May 26, 2008
  • May 26, 2008
Noise is as good of a barometer for fuel pump performance as it is for stinkyness of a fart. Don't go by sound alone and assume nothing.
Good luck.
87coupe50
105
WAYNESBORO, PA
May 26, 2008
  • May 26, 2008
well, I was gonna say change the fuel filter cause I just had a similar issue. Maybe you just have a ton of crap in the tank and need to flush or replace the tank.
ID89GT
1,659
18
49
Spokane Valley, WA
May 28, 2008
#10
  • May 28, 2008
  • #10
Well now it doesn't start at all. It just turns the engine but it never actually starts
HISSIN50
34
129
May 28, 2008
#11
  • May 28, 2008
  • #11
Good. That makes it easier. Check for spark. Check injector pulsing. Check fuel pressure. Go from there.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
