finally got the car together to the point where i need it to run and it will start then just die. when i held my foot on the gas it stayed running but then died again. i thought i had everything figured out when the car was still half apart and i just wanted to see if it would fire and it fired right up but the fuel pump was disconnected and the starting fluid ran out. i currently have the gauge cluster out of the car along with alot of the interior stuff because im replacing the carpet. would not having the cluster in affect the cars ability to idle? basically just wondering if there are common things that cause a start then die issue?
