89 Lx Hatchback Ignition/starting Problems.
TBrannon91
20
Lewis co Ky
Alright first of I'm new on here so hello everybody. I am working on getting a 89 out of a barn and somewhere I can work on it a little better. It's my ol ladies dads mustang that he picked up wrecked and stuck in the barn for a donor car. It's been in the barn for a year or so and he's had it running and everything since he got it.
He told me he got in it one day to crank her up and he got no response from the starter at all. He figured the starter was shot and didn't fool with it anymore after that.
I recently replaced the starter, got no crank, no clicks, nothing. Pulled out my volt meter and checked the starter solenoid and wasn't getting but about .74 volts to the starter side and .05 to the ignition. Battery side was 11.89 or so. I replaced the solenoid thinking that had to be it. Turned the key, nada. Went and bought a new ignition switch Thursday, put it in there thinking that had to be why I wasn't getting anything to the starter or ignition post on the solenoid. Nope. Still scratching my head and searching the Internet for possible quick fixes.
I'm new to mustangs as this is the first one I've tinkered with. Always had a GM since I was able to drive until my Mazda with a 2.3 ford motor. I'm looking for any help you guys can lend, I know I need to check the clutch saftey switch but I'm wondering if I could just get rid of it altogether for the simple fact that I don't want to replace it if that's not the problem.
I appreciate any help in advance.
-Thomas
I've looked over the check list a couple times. No need to post it on here as that's all that comes up when I search for ignition problems haha.
Can anyone tell me how to diagnose the clutch safety switch? Remove it? Cut the wires all off and spice them together? I don't know what would be best to do so any input at all is encouraged.
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Reactions: 1 user
