  • 2.3L (N/A & Turbo) Tech
89 not charging
  • Thread starter Thread starter vegasche13
  • Start date Start date Jun 25, 2010
V
vegasche13
  • Jun 25, 2010
Replaced the alternator and battery but alt still isn't charging batt. I noticed there was a 14GA green wire not hooked up to anything(coming from alt plug). I pulled up a diagram and it says it should be plugged into the solenoid. Is this correct? If so, which bolt on solenoid do I attach it to?? I tried hooking it up to the bolt that has wire leading to battery and the voltmeter on dash spiked to about 13 from 8, BUT the wire got really hot......is that normal?? Thanks in advance
Dan P.
483
N.C.
Jun 26, 2010
  • Jun 26, 2010
Hot wire is not good. You should be able to use this diagram
Dan
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
M
12 mustang gt check charging battery light
  • millerj7950$
  • Jan 24, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 14, 2026
BossHorseGirl
