Engine 89...starting
  • Thread starter Thread starter justin82
  • Start date Start date Dec 17, 2018
justin82
334
17
48
Dec 17, 2018
  • Dec 17, 2018
not sure how to describe it...sometimes the care fires right up, and sometimes it takes a couple seconds longer
thanks
RaggedGT
Mod Dude
Jul 20, 2014
4,769
3,227
203
Taylorsville ky
Dec 17, 2018
  • Dec 17, 2018
Start with the basics-
•Check spark plugs
•Check plug wires
•Check fuel filter
•Check fuel pressure
•Check air filter
•Clean Maf
justin82
334
17
48
Dec 17, 2018
  • Dec 17, 2018
did all that in april... but I didn't check fuel pressure...thanks!
Reactions: RaggedGT
RaggedGT
Mod Dude
Jul 20, 2014
4,769
3,227
203
Taylorsville ky
Dec 17, 2018
  • Dec 17, 2018
Still wouldn’t hurt to just go back over everything,and looking at the plugs can sometimes clue you in to any running issues you might have. Little odd problems can be a pain sometimes-but sounds like you’re keeping after it. I’m sure you will find it
Reactions: justin82
justin82
334
17
48
Dec 17, 2018
  • Dec 17, 2018
thanks
General karthief
Mod Dude
Aug 25, 2016
28,143
10,762
213
polk county florida
Dec 17, 2018
  • Dec 17, 2018
Check for codes?
Just think'n out loud
justin82
334
17
48
Dec 17, 2018
  • Dec 17, 2018
haven't checked for codes....didn't think about that...I will tomorrow....thanks
D
Deleted member 215073
Dec 19, 2018
  • Dec 19, 2018
Are you losing prime in your fuel system occasionally? Maybe a leaking fuel pressure regulator. Pull the vacuum line off the regulator and see if it spits fuel. Can you tell if it's running rich?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
