'89 Valve Cover Gasket Change Question?
  • Thread starter Thread starter Slo5Oh89
  • Start date Start date Nov 12, 2009
Slo5Oh89
226
Washington, IL
Nov 12, 2009
  • Nov 12, 2009
I have a '89 with leaking valve covers and am close to changing them. Is there something else I should check with the intake off? What Valve Cover Gaskets are best with the Stock valve covers? Are the spacers for the upper intake worth the money? Any help would be great. This message board is awesome I always get great feed back. Thanks again in advance.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Nov 12, 2009
  • Nov 12, 2009
Why are you taking the upper intake off to change the valve covers? Just remove the TB, spacer, air inlet.
Slo5Oh89
226
Washington, IL
Nov 12, 2009
  • Nov 12, 2009
You can get the driver side valve cover off with out removing the upper intake?!?! If so Awesome!
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 12, 2009
  • Nov 12, 2009
Its been a while since ive done a set of gaskets on a stock motor, but i dont think its possible without taking the intake off, and either way, its like 6 bolts for the intake, much easier just to take it off, will save time in the long run. and it will save you a TB/EGR gasket.
Get the ford rubber gaskets that are have a bonded metal ring in them. Ive had two sets on my car, both sets have been torqued over 15 times and never leak. DONT USE CORK, they suck.
Not really much to look for when doing it, just make sure that you tape the lower intake so nothing gets dropped in there, and if the upper to lower gasket comes off in one piece chances are you can re-use it if you are in a pinch, but i'd reccomend going to a parts store and seeing if they have one when you get the VC gasket
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Nov 12, 2009
  • Nov 12, 2009
Oh I remember the stock set up- The valve cover hits the intake.
Slo5Oh89
226
Washington, IL
Nov 12, 2009
  • Nov 12, 2009
Does anyone use the Intake spacers? They help much or just a hyped up add on?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Nov 12, 2009
  • Nov 12, 2009
They help with clearance which is why I use them. I don't remember a noticable gain or anything.
mineralgsvt
583
Carmel, IN
Nov 12, 2009
  • Nov 12, 2009
+1 - What he said.
68stang351
850
9
39
Savoy TX
Nov 12, 2009
  • Nov 12, 2009
Fel Pro makes some like that too, the Perma-Dry. That's what I use on all my stuff.
Awesome.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 12, 2009
#10
  • Nov 12, 2009
  • #10
Awesome.
I tried those on myne, and they were junk, the gasket was too thick and on my car when i tightened them, they loosened up and started leaking
68stang351
850
9
39
Savoy TX
Nov 12, 2009
#11
  • Nov 12, 2009
  • #11
That's strange. They've worked great for on both my pushrod motors. The 351 has had them for about 6 years and the 302 has had them for about 4. Never had a problem. And my 302's valve covers came off ALOT!
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 12, 2009
#12
  • Nov 12, 2009
  • #12
Mabye were talking about two different gaskets then.
68stang351
850
9
39
Savoy TX
Nov 12, 2009
#13
  • Nov 12, 2009
  • #13
The blue rubber ones with the metal strip in the middle, and it also has metal rings around the bolt holes to prevent squishing.
Just noticed I wrote "Perma dry", I think they are actually "Perma dry Plus".
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 9, 2026
joeybuddy96
J
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Fox 5.0 Mustang Tech Apr 13, 2026
Foxbodyjake
F
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
