9 in
faststang90
522
baytown texas
got some of my 9 in parts in. its 3in shorter on each side, back braced, fill and drain holes, set up for coil overs it has all the brackets for the anti roll bar. the control arms takes a 5/8 bolt to install it into the car so i have to drill the stock holes out to a 5/8 hole. my axles are 40 spline and the 3rd member has a spool in it and 4:11 pro gears. the car is going to have a bbf 547 in it and i have talked to the engine shop that is going to do the motor and he said that he just done a 572 with my heads but it was like a 11:1 motor and my is going to be like 13:1 13:.5:1 motor he said that the other motor maded almost 1200 hp on the dyno so it should be a fun ride down the track
