9" Rearend Question
  • Thread starter Thread starter wickedmach1
  • Start date Start date Dec 22, 2003
W
wickedmach1
376
Austin, TX
Dec 22, 2003
  • Dec 22, 2003
Any problems with installing 31-spline axles in a small bearing rearend housing? I understand that the 31-spline axles only were installed using the large bearings. What problems could arise if any? Thanks.
Edbert
3,548
32
109
Austin TX
Dec 22, 2003
  • Dec 22, 2003
They'll fit, 35s or 40s are too fat though. No problems other than the additional weight and parasitic loss.
W
wickedmach1
376
Austin, TX
Dec 22, 2003
  • Dec 22, 2003
I guess it is a stupid question to ask if pre-mature bearing failure is possible? What can I expect? Anyone running the small bearings and 31-splines?
D
D.Hearne
11,730
south louisiana
Dec 22, 2003
  • Dec 22, 2003
I'm running 31 spline axles with 9 inch small bearing ends in an 8.8 rear, no problems so far other than adapting my brake backing plates to the housing. Then again the bearing ends are the super small ( smaller than the small 9's ) Stang/ Ranger 7.5/ 8.8 brake pattern.
9
96 DOHC Cobra
542
Cerritos, CA
Dec 22, 2003
  • Dec 22, 2003
All the BOSS and CJ Mustangs, Cougars, Fairlanes, and Torinos came stock with 31 spline axles in small bearing housings.
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
