Any problems with installing 31-spline axles in a small bearing rearend housing? I understand that the 31-spline axles only were installed using the large bearings. What problems could arise if any? Thanks.
I'm running 31 spline axles with 9 inch small bearing ends in an 8.8 rear, no problems so far other than adapting my brake backing plates to the housing. Then again the bearing ends are the super small ( smaller than the small 9's ) Stang/ Ranger 7.5/ 8.8 brake pattern.
