Suspension 90 GT help with launch
vpap1
109
went to the T&T on wed night and got the GT to the track after 6 years.
My mph was indicative of my combo but my launch needs work
1.822 60' and a 12.67 et at 111.44 mph
team z street beast kit with relocated uppers, stock strings, strange 10 way single adj all around
front shocks set at 3 front full loose and rears are 5
launch at 4000 rpm, tires are et street r bias at 16 psi shift at 6000 rpm
combo is 347 trick flow top end kit with larger comp cam, full 3" exhaust x pipe mac dumps, 369 hp at tire
weighs about 3350 with me in it. estimated, no spare no rear seat, smog removed, basic weight reduction
front rises a bit, settle down good, but rear bounces in first gear, not tire hop or wheel spin
should i tighten the rear springs?!?!
video to follow:
View: https://youtu.be/RlSy51iN92k
thanks
Reactions: JD1964
