90 Gt No-start Issue
Vekxun
12
No clue where to start this off, so let's just get into it. I've got two fox body mustangs, a 90 GT and a 91 LX. The GT was factory original when I bought it last year; and this winter I decided to tear it down and give it more power. I'm not new to this sort of thing, and I've done several mustangs in the past few years.
My issue is this, I can't get the car to start/run. When I initially got the motor back together with all of the new parts, it wouldn't start at all. I assumed that I had the distributor 180 out, or that one of the components that I bought was just defective out of the box. It wouldn't be the first time that something like this had happened to me. I pulled the distributor (MSD pro billet, brand new) and replaced it with the stock distributor that was previously in the car; and it started right up. Ran without any issue, so I naturally assumed that the MSD distributor was defective and sent it back for a replacement. I drove the car for around 30 miles with the stock distributor and had no issues what-so-ever.
When I installed a second new distributor from MSD however, the no-start condition returned. It just cranks without firing up. Nothing was changed, I literally drove the car into the garage, pulled the distributor and dropped the new one in; and it will not start. So my initial reaction was "ok another defective distributor, the odds are low but fine stranger things have happened". So I pulled the distributor and put the stock one back in; expecting the car to start back up...Only it didn't.
So I decided to see if the new distributor was good, I put it into my 91 LX. It started right up with the new MSD distributor. Ok, so this distributor is good, what about the stock one I was using before? I put that into the 91 LX, and it also started the car fine. Both distributors are confirmed good, as they operate my 91 LX without any problems. Considering that I'm able to put 3 distributors into my LX and have them all work on the first try, I think it's safe to say that I'm not installing them 180 out in the GT.
Now I've been working on this issue for the last few weeks, following no-start check lists and re-tracing my steps double checking things and eliminating potential sources for the problem, but I'm running out of tests and check-lists at this point.
As I said, the car was factory original in stock form when I started working on it. Nothing was missing, all of the accessories are still there. I didn't remove anything, (AC, EGR, smog etc). It remains as it was in regards to that. I take my hobby seriously, and I have an appreciation for my vehicles that most people wouldn't understand. I didn't take any shortcuts when I assembled the motor; and I was very careful at every step of the way to keep from damaging anything; especially wiring harnesses etc.
Below are some noteworthy components that I've upgraded.
Factory 302 block
Comp stage 3 cam
AFR 165 heads
1.7 rockers
Cobra intake (ported by tmoss)
Adjustable fuel regulator
70mm throttle body
Walbro 190 fuel pump
As I previously stated, I've done numerous no-start check lists, but here are some of the things that I've tested or ruled out thus far (as far as I know anyway).
-I checked each cylinder for compression. The motor is averaging 165 on all cylinders, with none being below 160.
-I checked the brand new coil for voltage, it tested normal. (I even tried pulling the coil and putting the old one in; with no change.)
-I checked for spark with nothing out of the ordinary.
-I tried starting the car by spraying starter fluid into the throttle body, nothing.
-I checked to see if the car was getting fuel, it is. (Even though starter fluid should rule out fuel related issues)
-I checked for injector pulse with a noid light, the engine is getting pulse.
-I replaced the ignition switch, so it's brand new. Problem persists.
-I removed the car's computer and put it into my 91 LX; and the computer fired the LX right up. So the computer cannot be bad as it runs my other mustang without any issue.
-I swapped the fuel relay with the relay from my 91 LX to no effect.
-I tested the number 4 wire on the TFI harness (it has 12 volts with key on so the computer is sending signal correctly)
-I tested the number 6 pin on the TFI harness (it has 12 volts, so it has solid ground)
I've checked and re-checked most of these things several times by now. I'm not a master mechanic by trade, but I've done major engine work on 4 mustangs in the last 2 years and they've all come out with very positive results. The only other things I can think of mentioning are that after I finished the compression test, I thought what the hell let's see if it starts. I turned the key, and the damn thing actually started. However, after about 30 seconds I turned it off and tried to start it again to see if it would; only it didn't. It randomly just decided to start seemingly one time, and then back to nothing but cranking.
At this point the only thing I have left on my mind as a culprit would be a wiring issue that I haven't found, or the factory ford alarm that is still on the car is preventing the motor from firing. I don't know much about the alarm system, as it was an option that not many people paid for so my research hasn't turned up much yet; so I'm not sure if it's wise to start cutting into it.
Any help that anyone here can provide would be greatly appreciated.
When it won't start, do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Reactions: Michael vazquez
