900rpm shakes
ponypowa2
228
Destin, FL
My car has a nasty shake at 900rpm but smooths out over 1000 rpm
Things I replaced recently:
A few vacuum lines
EGR Valve
EGR Tube (it was cracked)
Spark Plugs replaced about 4 months ago (I checked them again recently, no bad plugs)
Cap + Rotor replaced.
Oxygen sensors replaced 6 mo ago.
Replaced/Cleaned MAF sensor
Recent oil filter/ oil change
Things I have checked:
vacuum lines
TPS tests out good (according to haynes)
cleaned IAC
Air filter cleaned
fuel filter replaced
could it be a dirty or clogged injector? Is there anyway to test if the IAC valve is working properly?
any help is appreciated
My car had a similar 'shake' around 1100 RPM, and it turned out my Harmonic Balancer was going out.
Take a look at the balancer and make sure the rubber seal isn't bad between the two metal pieces.
If you do need one, check out Ford Racing, Pioneer, TCI etc..
+1
look under your hood while your car is running. check to see if the HB is wobbling. its a tiny bit, youll be ok at the moment. just keep in mind. im changing out mine soon. just makes sure the rubber is not coming out. also to note that 1 of my friends on his gt, his is shaking also but its been ok for the last year.
my.php
Well the pic doesnt seem to work but heres a direct link to the pic on image shack. http://img373.imageshack.us/my.php?image=dsc00023ml4.jpg
