Electrical '91 Wiring Issues
Knowbody
35
26
18
TEXAS
Hey folks. I have a '91 notch that is now giving me some trouble.
The other day the car died on me while driving. It just shut off. When I turned the key, it just cranked and cranked. I could hear the fuel pump cycle on like normal, so I figured it was just a battery connection issue. I popped the hood, checked the wires at the battery and solenoid by wiggling them around, jumped back in and it fired up. Get going down the road and it did it again, repeat, again, repeat. Made it back home. So I made sure all of the connections were solid, good grounds, etc. Went for a drive with no issues, then it did it again out of nowhere.
So I said to hell with it, I'm going to disconnect everything and make sure all of the wires are in good shape, and get everything 100%. I have a 6AL box mounted off the shock tower, next to an Optima red top battery, and an MSD coil on the shock tower next to the solenoid. I decided to install an MSD 2-Step and Maradyne electric fan relay/temp switch kit while I was in there.
I unbolted everything, and pulled it all out of the way. Tucked away any unused connectors and wiring bundles that were previously just laying under the battery tray. I rerouted some of the wires inside the fender, shortened a few that were too long. Crimped and heat shrinked all the connections and terminals, added the MSD 2-Step and Fan Relay Kit, and ran everything through some wire loom. Now everything looks good, I'm feeling confident in the execution of the wiring cleanup and install.
While inside the car to install the manual fan and 2-step switches, I turn the key on to find a hot wire under the dash and notice that the turn signal indicators are lit solid, the backlight for my Autometer tachometer and back lights for the Oil/Water/Volt gauges are lit. Hmm, what the ? So I hit the headlight switch to make sure I didn't bump it. Now the OEM oil pressure gauge starts rising fast, what the ??? So turn off the headlight switch, cycle the key on, the fuel pump comes on for a split second, tach shift light flashes, and the signal indicators are on solid and autometer gauge lights are on again. I try to start the car, it cranks normal and lights off, idles for a second, but immediately dies. The fuel pump relay is clicking like normal.
So I start wiggling around wires under the column, and the ignition switch is practically hanging on for dear life. I unbolt it and it falls apart in my hand. So I run to the parts store and grab a new switch thinking this is the culprit to all of these problems. Install it, same damn thing. Same symptoms, same results.
What in the hell did I do wrong?
The MSD 6AL and MSD coil have been in the car for years with no issues. I believe the original issue with the car dying while driving, but starting right back up, was the ignition switch.
As for the new gremlin, 'm thinking I possibly got something mixed up at the solenoid/battery connections, since that's the only other area that was touched.
Today I'm going to rip it all back apart and retrace everything. FML
Thanks, I've gone through all of the wiring diagrams and can't figure out why the signal indicators, & autometer back lights are coming in. I'm coming down with a cold, so I guess I'm not going so work on the car today. I'll keep going through wiring diagrams so I can verify what I've done and if I missed something.
The die and wiggle the wires by the starter solenoid is possibly a wiring problem with one of the fuse links that live in the wiring harness in that area.
When the engine dies, do the checklist, pay special attention to the first part which is electrical. The fuse links supply power to the computer, fuel pump and ignition system. Look for low voltage or missing voltage at the fuse links and at the point where the wiring that feeds the power connects to the device or devices (lights, relays, ignition switch, etc.).
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Jrichker, thanks for the info. I have been reading up and looking at all of the schematics, and will be looking into the fusible links as a possible culprit.
What I can't seem to connect in the diagrams I'm seeing, is how the turn signal indicators and autometer gauge back lights come on when the key is cycled into the on position. Any ideas?
The Autometer gauge lighting needs to be wired into the radio light to work properly.
Do the hazard flasher lights work properly? The hazard flasher is located on the fuse panel, to try removing it see if the turn signal indicators go off.
The autometer gauge lights have been wired into the dash lights for years with no issues, nothing was altered, or even touched when it comes to the gauge lighting. It still doesn't make any sense to me why these lights are coming on.
I'll mess with the flasher and see what happens, good idea. Also, while looking over the diagrams, I remember the ECM ground with the barrel shaped connector, but I'm not sure if it got reconnected. It very well may have, and I forgot about it, but it also may have been left disconnected, meaning no ground to the ECM.
Thanks
So, I'm pretty sure I found the issue. Seems the yellow 18ga fusible link was previously melted, and halfass repaired, sometime in the past. They put a new fusible link in, but the crimped butt connector was the real problem. I replaced it with a new fusible link, soldered and heat shrinked this time, and rechecked all the wires in that harness bundle, then turned the key to on, and everything seemed back to normal. I didn't start the car because I had the msd and battery tray laid over the engine, etc. and I was about get carried away by mosquitos, so I'll finish it up this weekend.
You had a problem that I hadn't seen before, thanks for the feedback. I'll have to remember that one and add it to the alternator test path docs.
@jrichker yep, that was the issue. I fired it up today, everything is back to normal. But after that issue I decided to relocate the battery to the trunk, and reroute all underhood wiring to not only clean up the engine bay, but this will give me the chance to inspect every wire bundle, connectors, terminals, etc. Plus, I have some fresh parts I need to install, so nows the time to do it all.
I ordered a cut off switch, inline main fuse, and power distribution block to help complete the job. And since I only want to do this once, I picked up the fuel pressure gauge I've been wanting, as well as a line lock, and will finally install the nitrous system. This should get all upgrades that require wiring out of the way and I can finally move on to the real fun stuff.
Thanks for your help!
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10 gauge wire they recommend is even less adequate that the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/2" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug there is a green wire. It is the sense lead that turns the regulator on when the ignition switch is in the run position. Cut the green wire and solder the 40' of green wire between the two pieces. Use some heat shrink to cover the splices. See http://fordfuelinjection.com/?p=7 for some excellent help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire. Try to run the green wire inside the car and protect it from getting cut or chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs. Do not add the jumper between the 1/2" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies a turn on signal to the regulator when the ignition switch is in the Run position. Turn the Moroso switch to off, and the sense voltage goes away, the voltage regulator shuts off and the alternator quits making power.
The fuse & wiring in the following diagram are for a 3G alternator. The stock alternator uses a dark green fuse link wire that connects to 2 black/orange wires. Always leave them connected to the starter solenoid even if you have a 3G alternator.
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to the chassis ground where the battery was mounted up front. Use a 5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure that it the metal around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Note: The quick disconnect may have fallen victim to damage or removal by a previous owner. However, it is still of utmost importance that the black/green wires have a high quality ground..
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo shop will have them if the auto parts store doesn't. Use some heat shrink tubing to cover the lugs and make things look nice.
http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Vacuum diagram 89-93 Mustangs
Thanks again. I've looked at several articles on battery relocation for these cars to see what others have done, this isn't my first rodeo, but the first time doing this on a foxbody.
I'm using a Jegs 2-post cut off switch, relocating the solenoid to the trunk, and using a power distribution block to feed the main harness under the hood. 1/0 wire, copper connectors, stainless hardware, and heat shrink tubing should keep everything solid. I'm running the 3G alternator already, so this should all be a snap. Most of my parts should be here Tuesday or Wednesday so I hope to have everything wrapped up next weekend. Thanks!
be good to go.
Moroso diagram.
How it works:
ground problems.
Note:
@jrichker
Question on the negative wiring for computer dedicated ground - is it best to cut the cylindrical connector off, put a new ring crimp on both black and green wires, and ground at same point as chassis ground?
