92 2.3 Tuner?
  • Thread starter Thread starter badachew
  • Start date Start date Aug 29, 2007
badachew
  • Aug 29, 2007
Do the ECU tuners that work on the 5.0 cars work on the 2.3s as well? as after I throw a turbo on my 92 I'll probably need to retune the ECU and get a larger maf put on it. I already have a larger fuel pump and 36lbs injectors from a 94 supercoupe.
sleeper_inc
92
Regina Beach Sask. Canada
Aug 29, 2007
  • Aug 29, 2007
No, the computers used in the 87-93 2.3 mustangs have not been cracked. I'm not even sure a J3 can run on them even.
If you want a turbo with MAF get a LA computer with a J3 chip
badachew
  • Aug 30, 2007
It's not that I want to use a MAF at all, I'd rather just use what is in there stock. My plans are to just slap a turbo on the motor for now then swap a 5.0 in there later. If I wanted to stick with the 2.3 however I'd just use the Dodge Turbo SMEC anyways because I have a chipped one and a burner and I'm pretty good with wiring
sleeper_inc
92
Aug 30, 2007
  • Aug 30, 2007
Then wait and save money for the 5.0 swap, because this will run almost the same amount of money (depends on the engine prices though and you mechanical ability)
Blivit
99
Orlando
Aug 31, 2007
  • Aug 31, 2007
Not 100% correct. I work for SCT and our chips do work on these cars but we do not have full coverage of every ecm. They have the same J3 port as the 5.0 cars. I personally have one of our chips in my 93 4 cylinder where I modified some of the fuel and spark tables for better fuel economy.
badachew
  • Sep 3, 2007
I don't see how spending
40 dollars for the injectors (bought already)
150 shipped for the turbo and manifold
The I/C piping, and intercooler, and material for the oil lines I already have as well as an APFR and the exhaust I can make myself then sell to whoever I sell the turbo "kit" to when I'm done with the 4 cyl(maybe I won't be done with it and I'll keep it in there)
VS
Paying (local prices)
Complete EFI 5.0 HO motor with wiring and computer - 500
T5 Tranny & Clutch - 600
8.8 Rear end - 200
Plus I'm pretty handy . I'm not trying to sound like a jerk but slapping a turbo on the motor that is already in the car is far less work that pulling a motor. At least to me anyways
sleeper_inc
92
Sep 3, 2007
  • Sep 3, 2007
Add
Computer
VAM
Pistons
8.8 Rear end (if you want it to last)
VS
8.8 Rear end - 200
badachew
  • Sep 4, 2007
I'm not adding the computer or forging the bottom end because of the fact that the motor is just going to stay in there until it gets swapped out, and if I decide to keep it in there, then I'll swap in the Dodge SMEC and an actual turbo motor. The 7.5inch rear end is strong enough for everything I want to do with it. There will be no serious drag racing so that rear end won't blow apart. Plus the fact that there will be a detroit truetrac going in
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
