92 5.0 fuel pump question
Hey,
I have to get a new fuel pump for my 92 5.0 LX. The one I have in it is stock right now, and I want to replace it with pretty much the same application. Anyone know what comes stock in it? And does anyone have any suggestions as to what I should go with when I replace it?? Thanks in advance
Walbro is the oem pump. Stock was originally 88 LPH but was bumped up to 95 LPH at some point. A 110 is more than stock and 155, 190 and 255 are all really common.
I would get a Walbro (size is your choice - bigger pumps are often but a few bucks more than the next step down).
Good luck.
Go with a 255. Your fuel pressure regulator will keep it running the correct amount of fuel pressure. This way if you do build up your motor and decide you want more gas to the motor you already have the right pump.
