92' 5.0 stang has no spark...
  • Thread starter Thread starter kenny22922
  • Start date Start date May 5, 2006
K
kenny22922
  • May 5, 2006
This all began one day when I was driving home on base and the car just died on me with a pop inside the cab. I got it to the shop and found that the fuel pump was not operating and the coil was not sparking. After a lot of troubleshooting, I found that the hot contact of the pcm power control relay had no power. Thus from the fusable link or wire i guess burning up, so I ran a new one straight to the battery with a new fuseable link. So then the fuel pump problem was fixed, so I checked the coil for spark and still had none.
SO...I then started testing for voltage and continuity through the wire going from the neg. side of the coil to the computer and control module. I had the key run position with power going through the system and there was no voltage at all at pin(4) of the computer harness connector. Is this normal, I have read about a resistor in between the wire going from the coil and module to the computer but wouldn't there be some voltage at pin(4) regardless? Is my resistor bad you think, or what? And what caused all this to happen all at once??? Is there something anyone knows of that I might need to change before I fix the problem so things don't burn up again?
R
Raginstang
166
SANTA CRUZ CA
May 6, 2006
  • May 6, 2006
check the ignition module, that is located on the side of the distributor, were the harness plugs into, very common part to go bad on fords, and will cause no spark conditions.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
